04-05-2019 05:19
04-05-2019 05:19
After conducting several tests, I have reason to believe that my Alta HR does not track steps accurately in certain situations. I feel that a clip-based tracker (like the Inspire) will be far more accurate as step counting is my primary measure of progress.
That being said, I also enjoy the heart rate monitoring features and having a wristwatch, so I don't necessarily want to give up my Alta (even though I keep eyeing the Charge 3).
I have been trying to find out what exactly will happen if I have both an Alta HR and an Inspire on the same account and wear both devices all day. I understand that it is not recommended and that the data accuracy will be "compromised" but how so? I understand that certain criteria like GPS tracking will override non-GPS data, but that's not an issue in this situation.
04-05-2019 05:23
04-05-2019 05:23
Hi there, @LissaKristine! Interesting scenario. You can read more about using two devices at a time - or two on one account - in this Help page article.
04-05-2019 05:29
04-05-2019 05:29
@SunsetRunner That did not answer my question. I asked what exactly would happen if I wore both devices at the same account. Telling me the data accuracy will be "compromised" is not an answer. How will it be compromised? Will one tracker's data override the other's (keep in mind that there is NO GPS on these devices, so which one would take precedence?) Would the total steps from each device be added together? Would they be averaged out?
I wish people would stop sending me a link to the help page article and actually ANSWER the question asked.
04-05-2019 05:54 - edited 04-05-2019 09:52
I’m just a volunteer here and not privy to all the Fitbit algorithms so cannot give you a specific answer as to exactly how the data will be “compromised.” Hopefully someone will step in with more information than what is below from the Help page. But the answer in the Help page (below) specifically recommends you not wear more than one device at a time.
Let me tell you my trick, even though it does not answer your question. But it addresses your situation. Like you, I’ve noticed that there are time when my watch device does not track steps accurately. (Pushing a shopping cart, anything where the arms are not in motion). When I run into these situations, I move my device to a pocket or to a purse that rests on my hip. It counts steps nicely there and when I am done, I put it back on. Steps are seamlessly counted. This will skew your heart rate info but depending on the device, you can always turn HR off when it’s not on your wrist.
From the Help pages ... If you have more than one device paired to the same account and you forget to take one off before putting on another, we’ll reconcile the overlapping data to present the most accurate information possible on your dashboard. For example, if one of your trackers is using GPS and another is not, your dashboard chooses the GPS data when calculating total distance since GPS provides a more accurate distance measurement than step counting alone. However, the more overlapping data that exists on your account, the more likely it is that your dashboard's accuracy will suffer. For best results, don't wear more than one device at a time and sync each device before taking it off and putting on another.
