09-26-2019 19:20
09-26-2019 19:20
I have a fitbit and would like to install futbit connect on my desktop computer and my daughter's will I be able to do this and have my steps sync with the connect on either computer?
Best Answer09-26-2019 19:59
09-26-2019 19:59
If you have Windows 10 with bluetooth, what you want to use is the Fitbit app from the Windows store. And that will let you sync. As for both computers, you should be able to but if they are both near, sometimes it helps to temporarily turn off bluetooth on one of them to sync with the other.
