12-16-2019 18:36
12-16-2019 18:36
this model has the stupidest replacement band with itty bitty pins. buyer beware
Best Answer12-16-2019 19:05
12-16-2019 19:05
Hi @mmdecarlo you posted this in the Charge HR forum area, but you mentioned the Inspire. Which one do you have and what is the problem? Your post can be moved into the forum area for the Fitbit style you have.
12-20-2019 13:18
12-20-2019 13:18
@mmdecarlo are you sure that you have an Inspire(no side button) the inspire band does not have any pins but a notch that clips onto a tab.
