keeps vibrating when phone low battery
ANSWERED
it keeps vibrating when my phone is running low this is annoying i dont need or want this feature does anyone know how to fix it?
1 BEST ANSWER
Accepted Solutions
Hi @beefcakesclappi Welcome to the Fitbit Community!
Thank you for your message letting us know about the inconvenient with your Inspire 2.
Please follow these steps, some of which you have already done, but the order is important:
  • Restart your Inspire 2.
  • Please on mobile device, go to Settings>Bluetooth, and remove all connections that exist with the tracker. (Forget, ignore or unpair device depending on the phone OS version)
  • Turn off Bluetooth and restart your phone. (switch off and on again).
  • When the phone is back on, turn on the Bluetooth again, but DO NOT attempt to connect to the tracker from here.
  • Go on the app. From here, try setting up the tracker as a new device.
Try to set up your notifications again. How do I get notifications from my phone on my Fitbit device?
1 REPLY 1
