7 Minute Workout in Fitbit Versa
How do I get the 7 minute Workout in my Fitbit Versa watch ? I used it the very first day when I bought the watch but then it has disappeared!
I have installed the Coach app in my Android mobile and selected a program. In my watch I could only see "Get Moving" and "Muscle Mix".
This is extremely disappointing. I know I can open it on my phone but the whole point of having the watch is to do the workout using watch. All the marketing material for Fitbit Versa has this feature mentioned as a selling point but it just not there!
8 REPLIES 8
I only see 3 workouts in Coach. 10 - Minutes Abs, 7 - Minute Workout and Treasure Chest. I do not see the others that you mentioned. Is it possible that you purchased Coach Premium? Is so, did you purchase
it after you used the 7 - Minute Workout?
You might try removing the app, syncing your Versa and then adding it back.
I do not have Coach premium.
The three exercises you have mentioned, I saw the very first day when I bought the watch out of which I used the 7 minute Workout once. After that I downloaded the Coach app in my Android mobile and logged in with my Fitbit account. And the exercises disappeared.
I have already tried what you have mentioned. Removing and adding it back in my watch did work. I saw the three exercises again, but then after a lil while it vanished again. I have tried logging out and removing the Android app as well. None of that works.
I'm not sure why Fitbit has decided to make such a simple thing so complicated. I want the 7 minute Workout in my watch, I should probably just pray to God for it to magically appear again.
I have the same problem on Versa and the iPhone 7. Until I downloaded Coach, 7 minutes of workout was available in my watch. I tried to delete the app from my watch and reinstall it. Once they showed the standard exercises and the required 7 minute work, but after the synchronization again I have a Coache exercise. I've already deleted the app and reset it 5 times in my watch. I deleted the app from my phone. I find it quite crazy to have to re-delete before every exercise and upload the app to my watch. Could someone from Fitbit send advice on how to avoid it and have the 7 and 10 minute workout as in the basic version?
I feel you. I have the same problem and am annoyed by it. It should be so much simpler than this.
Let's hope that maybe someone from the Fitbit Team reads this and answers or something.
Same here. Opened it twice, then it disappeared. I want a very quick and easy workout that I'll actually DO. That was it. It should always be an option!
I have the same problem and I try to find a solution.
Ok, I have bought the Premium account and added 7 minute workout in Favorites. I supposed that my favorite workout will be my personalized one and I will see it in my Fitbit Versa. But no, my personalized workouts are the same, nothing's changed.
This affects me too. So frustrating that you have it in the free app, but when syncing they take it away so they can sell it back to you with Premium.
The last tile on the Coach says: Sync in the Fitbit app to get new workouts. HOW DO I OPT OUT? OR SELECT THE ONES I WANT?
I know writing in all caps sounds like shouting. That was intended.
-edit-
Apparently the only way to get the app back is to revoke all Fitstar permissions: https://community.fitbit.com/t5/Fitbit-Premium-Coach/More-Fitbit-Coach-Workouts-on-Ionic-amp-Versa/m...
