07-11-2018 07:49 - edited 07-11-2018 07:57
Anyone having a problem with the 7 day step counter not syncing. Spoke to Fitbit tech said there was a bug in the new upgrade will take a while to fix. My dashboard still works okay, just the 7 day counter
07-11-2018 08:06
07-11-2018 08:06
Yes! I noticed that the 7 day tracker has been static for 2 days. It syncs one time a day and then never updates again. My "status" on community pages doesn't change throughout the day.
The other wierd thing I noticed is my stair tracker doesn't seem to be working. I tested yesterday and found that when I come up from the basement to the main level of the house, it counts as a flight. But going from the main level to the 2nd floor, it didn't add a flight. I tested several times.
Today I went swimming and then came up from the main level to the 2nd floor and it shows that I have "8 floors tracked" when I should only have 1.
Best Answer07-11-2018 08:12
07-11-2018 08:32
07-11-2018 08:32
Mine is a iPhone issue didn't say about Android
Best Answer07-11-2018 08:37
07-11-2018 08:37
Thanks @oreop
07-11-2018 09:18
07-11-2018 09:18
Do you also notice this through the web interface at https://www.fitbit.com/friends
07-11-2018 15:26
07-11-2018 15:26
Having same problem... With community steps/7 day only. On IPhone. Have uninstalled and reinstalled and did not fix the problem.
Best Answer07-11-2018 15:28 - edited 07-11-2018 15:29
@Rich_Laue Yes, same problem on web interface. My 7 day steps are static there too - match the counter on app.
