02-17-2019 15:47
02-17-2019 15:47
As I read all similar posts There is defintely a glitch in this Fitbit upgrade .. Please advise us is our product will be replaced ??
Best Answer02-17-2019 16:22
02-17-2019 16:22
Hi, I really understand your frustration after the update, but you do not mention the problems you're facing, only want to know if you can get a replacement. Please, in order to help you as the best possibl way, is to tell us what kind of problems you're facing after the update.
Best Answer02-17-2019 17:33
02-17-2019 17:33
Best Answer02-17-2019 17:41
02-17-2019 17:41
Hi Deb, two suggestions:
1: Close the Fitbit app on your phone and deinstall it (do not remove or unpair your Versa). Restart your phone and reinstall Fitbit app again and, of course, enable BT.
2. If that does not solve your problem: contact Customer Support.
Best Answer02-17-2019 20:32
02-17-2019 20:32
I agree that there is a pattern here. People that are having issues will post, those that are happy and not having issues will not post.
02-18-2019 12:43
02-18-2019 12:43
