04-24-2019 18:35
04-24-2019 18:35
It says I can select up to 7 stats, but the only options given are Core Stats, Hourly Steps, Heart Rate? How do I get it to display anything else?
Best Answer04-25-2019 12:03
04-25-2019 12:03
Apparently I needed to update the Today app. All good now!
Best Answer04-24-2019 20:06
04-24-2019 20:06
If you just set it up, give it a little time. Other choices will appear soon, at least within a few hours, probably sooner.
Best Answer04-25-2019 06:33
04-25-2019 06:33
Still nothing else showing today. Not sure what I'm doing wrong.
04-25-2019 12:03
Best Answer04-25-2019 12:05
04-25-2019 12:05
Glad you got it. That's probably what I had to do too. I guess I had forgotten exactly how I got it.
Best Answer09-01-2019 20:31
09-01-2019 20:31
I have the same issue with my new Vera lite. How did you update the today app?
Best Answer09-01-2019 20:56
09-01-2019 20:56
Today > profile pic > Versa Lite > Apps > Today
Best Answer09-01-2019 21:11
09-01-2019 21:11
Sorry - I’m not following those instructions ... click on today in the app and then profile pic? I don’t see that. I’m in the iOS app. Do I need to do this from a computer?
Best Answer09-01-2019 21:15
09-01-2019 21:15
I figured out how to update it but I still only have core stats, hourly stats and heart rate. Hmmm.
Best Answer09-01-2019 21:18
09-01-2019 21:18
Thanks for your help - I wasn’t patient enough. 5 minutes later the other stats appeared. 🙂
Best Answer04-06-2020 02:42
04-06-2020 02:42
How long did you wait?
I had to factory reset mine yesterday and 24 hours later I still can only have the core stats 😪
