12-30-2018 11:45
12-30-2018 11:45
Does anyone have 2 Versas & switch between them regularly? I have a Versa, a One & a Blaze & I use each for different reasons. I use the Versa most of the time, but I use my One for yardwork. I use my Blaze when I sleep or exercise while the Versa is in need of charging. I know if I use 2 Versas, they would need to be deleted & added to my account, but I could put different music on each--also, the Versa is more accurate than my Blaze. I'm wondering how difficult it might be to switch back &forth
Best Answer12-30-2018 23:12
12-30-2018 23:12
@JeniP It is possible but painful. Each switch is a setting up Versa as a replacement device again.
12-30-2018 23:12
Best Answer12-31-2018 03:32
12-31-2018 03:32
Thanks! I was thinking it might be too involed & time consuming.
Best Answer12-31-2018 13:01 - edited 12-31-2018 13:04
@JeniP Yeah. I personally use Charge 3 and Versa. Used to use Charge 2 and Versa. Of course, you cannot load music on Charge, but for all other purposes it's a great tracker. Just as a side note: I cannot receive notifications on both Charge 3 and Versa. It's always Versa only. It's because, for now at least, Charge 3 and Versa/Ionic are not meant to co-exist under the same account.
