01-02-2019 17:05 - edited 01-02-2019 17:07
I enjoyed my Fitbit Versa for several days after Christmas, but when I tried to download a particular app, it would only buffer instead of actually downloading the app. It did that for about half a day. After trying uninstalling the app and turning my phone and Versa off and on without success, I factory reset the Versa so that it might stop it. Although the factory reset did allow me to stop the download of that app, the Fitbit Coach app is now doing the same thing. If I factory reset it again, I’m afraid I will just have the same problem when I try to download the app. Any suggestions?
01-02-2019 20:52 - edited 01-02-2019 20:53
@Alhamrick17 Do not perform factory reset. In most cases there's no need. What is your phone model and OS? It seems like there's no stable bluetooth connection and that's why the apps do not get loaded to your Versa. Does your Versa sync properly? When was the last sync (check Fitbit mobile app > tap Versa icon and scroll down to the Sync section)? Fitbit Coach app can be updated only via WiFI because it's large (large for Bluetooth only). Please do the following to restore the connection and update/install Coach app:
Note: You need to put Versa in a charging dock only if you require WIFI e.g. for loading music, installing large apps (like Fitbit Coach, other apps do not need it), large clockfaces (Fitbit Labs clockfaces), or performing a firmware update.
Additional tips if sync issues persist:
