04-30-2018
13:09
06:30
EstuardoFitbit
04-30-2018
13:09
06:30
EstuardoFitbit
None of my apps will install!! Installed a couple to begin with (2048 and leaderboard) and then after that a couple of days later every time it would just get to the download bar being full and then return to the install icon
Very frustrating!! Any tips? Is anyone else having the same problem?
Best AnswerI forgot to say you have to use a different phone than the one paired to the Versa. At least, this was my case
Best AnswerHow did you do that? I’m currently re-installing an app that deleted itself when I pressed update and it won’t work?
