01-12-2019 11:56
01-12-2019 11:56
I am wondering if it is possible to use the bands from Charge 2 with Versa? Do they use same connection mechanism?
Best Answer01-12-2019 12:05
01-12-2019 12:05
Hi @sandeep.iiit and welcome to the forums. Sorry to say but no, the bands from those two devices are not interchangeable.
01-12-2019 12:05
01-12-2019 12:05
01-12-2019 12:06
01-12-2019 12:06
Hi, I'm afraid not. The Versa is a square watch ad and has a different diameter. Probably the connection mechanism is the same, cause the Versa is my 4th Fitbit and all had the same mechanism.
01-12-2019 12:13 - edited 01-12-2019 12:14
Thanks. So the different size of the watch can change the overall circumference of the band on the hand. So the same band might or might not work wrist-size wise.
It would still be nice to get a confirmation whether the connection mechanism of charge 2 band would work with Versa.
01-12-2019 13:19 - edited 01-12-2019 13:22
@sandeep.iiit It's not just the size of the tracker face, but the design of the clasp mechanism itself. The Charge 2 band clips on to the tracker from the face. The Versa uses a spring loaded pin. There are tiny holes in the Versa. The pins fit in to the holes.
They are not compatible.
Check out this Fitbit video
Laurie | Maryland
12-16-2019 14:28
12-16-2019 14:28
I have both. The charge 2 is much narrower where the band connects to the Fitbit. So for the versa you would need a wider band.
