04-07-2018
08:15
19:45
EdsonFitbit
04-07-2018
08:15
19:45
EdsonFitbit
I currently use Google for our phone provider and looking at the compatable list of phones for Google and none of their phones listed are no longer available for purchase. They have new phones and they will not work with Fitbit. Does anybody know if they will be updating the Fitbit to work with newer phones? What good is the Fitbit if they are not current with the newer phones? Maybe Apple is the answer. Might be more initially but then again if I get Fitbit it doesn't work at all.
Moderator edit: added label
04-07-2018 08:17
04-07-2018 08:17
I also chatted with a rep and ask if there are any plans to work with other phones but not could tell me. Just could provide what is listed online.
Best Answer04-07-2018 08:30 - edited 04-07-2018 08:31
my phone (huawei p10) is neither on the supported list and it works just fine with a charge 2. i'm not sure it'll allow you to set it up for the first time so i ordered a dongle for myself for my versa to set it up on a pc, but generally as long as your phone supports bluetooth low energy, and seeing that google pixels are fairly new phones, it might work nonetheless! after you set it up with your account via the pc and log in through your phone, it should sync just fine.
04-07-2018 08:39
04-07-2018 08:39
Best Answer04-07-2018 08:43
04-07-2018 08:43
That's odd, my boyfriend's Charge 2 works just fine with his W10 laptop via the dongle. However, if it works with your desktop, set it up there (just so that the device is connected to your Fitbit account) and then log in to your Fitbit account on your phone with Bluetooth on. The device synced up for me after a few minutes (because of a lot of data being pulled). What exact model of phone do you have?
Best Answer04-07-2018 08:54
04-07-2018 08:54
Best Answer04-07-2018 11:20
04-07-2018 11:20
I use a ZTE Axon 7 with my Versa. Used it with my Blaze. Is not listed as a supported device but works with no issues.
Best Answer04-07-2018 12:41 - edited 04-07-2018 12:41
The Windows 10 application supports multiple devices at once and even if it didn't, there's always the possibility of switching accounts to set up a new device. It's only about the initial setup to add the device to the account, but it might work even without the dongle via your phone.
Best Answer04-07-2018 12:53
04-07-2018 12:53
Best Answer04-07-2018 13:46
04-07-2018 13:46
Windows 10 computers are, generally speaking, all the same. If have access to BTLE or if you have a dongle, it should just work. Because Windows 10 is essentially the same system no matter the manufacturer of the computer, it will always be "compatible."
Android phones are a different matter. The system is really open source, so the manufactures are able to twist it to the benefit of the phones they're making, therefore, even if two devices have the same version of Android, there might be substantial differences if they're from two different brands.
Now, what's happening is that Windows 10 has Bluetooth Issues with Fitbits in general. So it may work for a while, but then all of the sudden an update to the Fitbit App or for the Fitbit or for Windows may screw things up.
Nevertheless, here are some things that we should always take into consideration.
04-08-2018 12:31
04-08-2018 12:31
I have used my Pixel and Pixel 2 XL with my blaze with no issues for the last few years. I expect the same will be true with my Versa but I won't know until it arrives at end of week. I'd be surprised if you had any issues though.
Best Answer04-08-2018 12:43
04-08-2018 12:43
Best Answer04-15-2018 06:45
04-15-2018 06:45
Thanks for the info. My daughter-in-law just purchased from Google Fi their Moto 4X that's not listed on Fitbitd compatable list and it did sync with the Versa.
She shared with me that you use WIFI to transfer music from the computer to the Versa so the Bluetooth problem we have with our laptop will not be a problem as we will use the phone to sync and the laptop to transfer music over there WiFi. I guess we can order our new phones.
Best Answer04-16-2018 09:09
04-16-2018 09:09
Hello everyone, I hope you're doing well, it's nice to see many faces around! ![]()
Please note that many Android phones have all the hardware requirements to be a supported device but are currently not on our list of supported devices. This means that we have not tested it for compatibility and added it to the list yet. For the time being, we don't have an specific date or time-frame of when is going they will be listed as compatible.
While these devices has all the specifications to be compatible and are currently working with the Fitbit app, it's possible to come across some issues along the way. I appreciate your understanding while we work to improve this experience, if there's anything else I can do for you, please feel free to reply.
Best Answer04-16-2018 09:15
04-16-2018 09:15
