01-25-2019 23:55
01-25-2019 23:55
My phone is connected to my Versa through bluetooth and when I use Spotify on my phone I can control the playback on the Versa but it says "Artist info not available"? Was workinf at first then had this issue
01-26-2019 17:18 - edited 01-26-2019 17:20
Hi, Spotify itself does not work on/is not supported by the Versa. The only thing you can do is control the volume of Spotify via your Versa with the app SpotifyHR. So it's obvious that your Versa is not showing the Artist name. If you go to All Apps within your fitbit app and search for Spotify, you will only find the SpotifyHR app as mentioned before.
