05-17-2018 06:30
05-17-2018 06:30
I have the special edition versa and my auto screen wake no longer works when I turn my wrist? I now have to touch the screen or push the buttons.
How can this be fixed? I have already tried to reset it 3 times but still no luck.
05-17-2018 06:33
05-17-2018 06:33
Could it have been accidentally disabled? If you press and hold the left button for a couple of seconds you go to the quick settings where you can turn "screen wake" to auto or manual ( you may need to swipe left / right to see that setting)
06-18-2018 06:55
06-18-2018 06:55
Just got my Versa yesterday and I'm having the same issue. Auto screen wake is activated but no matter how dramatic or normal my wrist movements, the screen doesn't wake. Didn't happen with my Blaze like that so I am familiar with the auto wake... help!
07-09-2018 08:08
07-09-2018 08:08
Thank you!
In my case, "accidentally" meant toddler-interference 🙂
07-09-2018 08:12
07-09-2018 08:12
Isn't it amazing how toddlers can find button combinations in seconds when it takes us hours to find them!
I haven't got my TV back to normal since a visit from a 3 year old a few weeks back.
10-09-2018 07:42
10-09-2018 07:42
I have that problem from time to time and it seems random. Sometimes no movement can make it wake up, but then a minute later it will be working like normal again. It must be a software thing.
12-19-2018 15:38
12-19-2018 15:38
Holding the Left button and setting to Auto, is the trick.
I've had to reset my fitbit several times to factory settings, since getting it back in June 2018, this is the first time I had to find this setting. This should be in the main settings, not hidden.
Thanks for the help finding this!
Best Answer12-19-2018 15:53
12-19-2018 15:53
Hi, you have to do two things to get it working again:
1. As stated before, press and hold the left button for a few secs untill the activity screen appears. When screen is, accidentally or not, set to manually, press it and it will switch to automatic.
2. Reboot your Versa by pressing and holding the left and right lower buttons untill you see the Fitbit logo. When you have seen that, release the buttons.
After that it should work again. Good luck.
01-14-2019 22:45
01-14-2019 22:45
03-08-2019 10:54
03-08-2019 10:54
My new versa arrived today, and I can't get it to light up consistently either. It will work if I hold it under a light though. very frustrating! Screen wake is on Auto, Notifications on. Thinking about returning it....
03-11-2019 13:24
03-11-2019 13:24
Thank you! I don’t know how it got accidentally set to Manual but it’s working now.
Best Answer04-30-2019 19:09
04-30-2019 19:09
I put a new watch band on today and accidentally disabled that function. Thankfully I got the answer quickly from these posts. Thanks Fitbit Community.
Best Answer07-23-2019 08:02
07-23-2019 08:02
Your post was older but the first thing I found when googling. Thanks! Somehow I must’ve switched to manual wake. Also solved the mystery of why I wasn’t getting notifications either!
Best Answer07-25-2019 10:16
07-25-2019 10:16
Thank you! This worked!
Best Answer08-09-2019 06:40
08-09-2019 06:40
Yup, mine was operator error, Haha, Silliness is a fun place to be.
thanks
Best Answer09-02-2019 10:33
09-02-2019 10:33
Thanks it works for me, option mistakenly set to manual mode.
Best Answer11-03-2019 11:10
11-03-2019 11:10
Same here, it's set to auto but I have to tap it couple of times to wake up, otherwise it just makes the b/w screen a little more brighter.
Best Answer11-18-2019 13:24
11-18-2019 13:24
thanks, same here, accidently on manual somehow
Best Answer03-26-2020 18:58
03-26-2020 18:58
Thank you! It worked!
Best Answer07-30-2020 06:49
07-30-2020 06:49
I tried your advice and restarted my versa 2 several times and than went to the setting.
however the manual option of the wake up screen is dim and doesnt respond.
what can i do to make the versa 2 wake up automatically?
