08-28-2019 04:41
08-28-2019 04:41
@Lwoodcock858 welcome to our Fitbit Community! I'm happy to assist you with your Fitbit Versa since the battery is not lasting as long as it should.
Please try the tips that are listed in this help article. These tips are helpful in order to improve the battery life of your Versa. After this, monitor the battery's behavior and see if the issue gets fixed.
Keep me posted on the outcome! 😀
Best Answer08-28-2019 06:03
08-28-2019 06:03
I'm having the same battery issue since the last update. Syncing more often!
Best Answer08-29-2019 08:09
08-29-2019 08:09
Hi
I have already turned off notifications, have no alarms set on my versa and yet I still now have to charge it each night.
Your website states Versa battery life is 4 days which at the moment mine can hardly stay charge for 24 hours, this is without tracking any exercise, which is the reason I bought the Versa.
This issue seems to have started only when I updated my account on the recent update.
What are my options here, can I have a replacement ?
Regards
08-31-2019 09:58
08-31-2019 09:58
@Lwoodcock858 I'm sorry for the late response. However, I appreciate the time spent trying the troubleshooting steps shared above. I was able to get in touch with our Support team and was told that they assisted you via email. I would like to follow up and would like to know if the instructions provided were helpful.
@bindiw thank you for your participation in our Fitbit Community. I would like to help you with the battery draining issues that your Versa is experiencing. Please try the troubleshooting steps that I shared in my previous post. After trying these tips, use your watch and see if the battery lasts longer.
I'll be around if any question arises.
