12-13-2019 08:30
12-13-2019 08:30
After the 32.70.7.14 firmware update, I seem to have a battery drain issue. This happened the first night of the update and again, today. I charge my versa and then turned off the watch. This morning I turned it on and the battery was at 60%.The first time this occur, it also was at 60% when I turned it on. May be part of the bug or just a coincidence. I did a factory reset after the first time, hoping this would fix the issue, but apparently not. Anyone else seeing this issue and if so any ideas?
12-13-2019 09:07
12-13-2019 09:07
I am having similar issues. On top of that - I used to turn it back ON using single click of any of the three buttons, now post update I have to press left and bottom right for 10 seconds which is so annoying.
12-22-2019 10:33
12-22-2019 10:33
I'm also having issues after the firmware update. Last night, battery was at about 60%. I turned my Versa off, and this morning it would not turn on. Placed in the charger, and it indicated that battery was at 0%. And it also seems to be draining faster when turned on. They definitely messed something up. It's hard to believe that an update that was not properly tested was released. So annoying.
