08-08-2018 05:34
08-08-2018 05:34
the fitbit low battery icon is overlapping with some info on the clock face I have chosen. Is there any way to disable that icon? I have a picture but have no clue how to attach it.
Best Answer08-08-2018 07:39
08-08-2018 07:39
I don't believe any Fitbit clock face has a battery icon so you must be using a 3rd party face. I would try another face and then possibly reinstall the existing face to see if the problem is rectified. If it is not, contact the clock face developer and see if they can fix it for you.
08-08-2018 07:54
08-08-2018 07:54
Best Answer08-08-2018 08:01
08-08-2018 08:01
No, you can not disable the Fitbit battery icon which is a part of the Today screen. I use a clock face which has a battery icon also but the Fitbit icon doesn't show in any way unless the Today screen is activated.
08-08-2018 08:14
08-08-2018 08:14
Best Answer08-08-2018 10:12
08-08-2018 10:12
Your picture is not showing. In any event, the 3rd party developer controls what appears on his clock face so you need to contact him if you insist on continuing with the same clock face. I have had very good experiences with 3rd party clock face developers answering queries.
