Battery was working well for a couple of months before battery life started to drained. I have charged the watch the day before and switch it off. The next day i am not able to switch it on. After trying to switch it on by pressing the left and right button together for 10seconds it works. However the battery life went from 100% to 34%. I wore it for less than 4 hours and the battery life went from 34% to 16%.
Is anyone facing the same issue?
Try restarting the tracker several times. Ifbthat doesnt improve the battery life try a factory reset (settings app on the watch and scroll down to About). If it is still not improved you will need to contact Support (link in my signature) Let us know how you go
Helen | Western Australia
Best AnswerI have the same issue with battery life.........I've only owned my watch since the end of May and it started needing to be constantly recharged in July.........these past few days I have had to recharge it every 12 hours or so! I thought Versa was known for good battery life??? FOUR days? NOT!
