04-17-2018 15:54
04-17-2018 15:54
I know it's only been a day, but has anyone figured out the best way to track spinning? Would it just be categorized under the "bike" preset?
Best Answer04-17-2018 16:05 - edited 04-17-2018 16:11
From the app I went to the Versa picture, tap it and go to "exercise shortcuts". That is where I searched for spinning and added it. If you already have 7 exercise shortcuts you will have to delete one then press the “plus sign” at the top and spinning is a choice in the list. I think the Bike exercise is for outdoor cycling with GPS
04-17-2018 16:02
04-17-2018 16:02
Hi @madisoncate,
There's actually a dedicated Spin mode, that I'd recommend using. Take a look at the article below for the steps how to do this.
06-11-2018 08:19
06-11-2018 08:19
Hello, I can not add spinning to exercise, can anyone help me, my mailadres is jankimpe@telenet.be
06-11-2018 08:25
06-11-2018 08:25
Excuse me I found it
Best Answer08-02-2018 09:05
08-02-2018 09:05
Did you have issues with your updated activities appearing on your device after you had modified them within the app? I added spin in the app and it's not showing up on the actual watch even after syncing and restarting
01-15-2019 05:52
01-15-2019 05:52
Thank you! Yes
Best Answer01-15-2019 05:52
01-15-2019 05:52
Thank you!!
Best Answer05-09-2019 13:26
05-09-2019 13:26
I have the same problem . When I look at the app on my phone or computer the Spinning workout is there , but when I open the exercise on my versa it is not
Best Answer05-09-2019 13:27
05-09-2019 13:27
Same problem here
Best Answer05-16-2019 19:11
05-16-2019 19:11
After removing an exercise you don’t want and adding spinning, you need to click on the word versa on the top left corner (on your phone). You will go back to the previous page and there, under the All -Day sync you will see green Sync Now. Press that. Make sure your Fitbit is charged. After that you should see Spinning in the Exercise list on your watch.
Best Answer07-01-2019 22:15
07-01-2019 22:15
Thanks.. This was definitely helpful
Best Answer01-26-2020 13:49
01-26-2020 13:49
How do I get ‘Spinning’ to autotrack? It comes up on my exercise shortcuts fine but doesn’t come up on the autotrack option. Anybody know how to do this?
I keep having to do it manually and almost always forget to start/stop it.
Best Answer01-26-2020 14:47
01-26-2020 14:47
@AGC63 Sorry, but spinning is not auto-recognized. I really wish that spinning could be auto-recognized. I have seen accelerometer tracings from people on a stationary bike. If a person can develop an algorithm to say that this is spinning or a stationary bike, then that person deserves a huge bonus!
Laurie | Maryland
Best Answer01-26-2020 15:06
01-26-2020 15:06
