12-27-2018 21:39
12-27-2018 21:39
We had to perform a factory reset on my fit bit versa (it kept receiving text messages from the wrong phone even though it was deleted from that phone) and after the reset now all I see on the screen is the blinking logo that says "to start, download the fit bit app" and I can't do anything else. When I log into the app on my computer it doesn't recognize the Versa and says it can't find it. One of the suggestion on the board was to unpair any Bluetooth devises but I can't even access any functions with the watch. All I see is the logo blinking with the "to start, download the fit bit app" in different languages rotating on the screen. HELP!
Best Answer12-27-2018 22:40
12-27-2018 22:40
What phone are you using? Unpair any other bluetooth devices from your phone and remove any bluetooth devices you cant turn off out of bluetooth range.
The versa cant receive notifications from a phone if you go to the phones bluetooth settings and and unpair it. (Removing it in the app only wont do it). So make sure you have done that as the bluetooth pairing to the other phone is very possibly preventing pairing with another phone for set up.
These articles might help too
Helen | Western Australia
12-28-2018 09:38
12-28-2018 09:38
Thanks for the help on unpairing - I did that. Now, what do I do about not being able to access anything on the Fitbit after the factory re-set. I just have a blinking logo.
