06-08-2019 03:15
06-08-2019 03:15
Hi just want to know what are the best compatible Bluetooth earphones for versa? What is the Bluetooth compatibility 4.0 or 4.1? Thanks.
06-08-2019 15:23
06-08-2019 15:23
The Versa uses BT 4.0.
Best Answer06-08-2019 15:38
06-08-2019 15:38
Any pair of bluetooth headphones will work mate!
Bluetooth is backwards compatible with older versions. You needn't worry about 4.0 and 4.1. It all just works!
Best Answer06-08-2019 16:44 - edited 06-08-2019 16:45
Hi about with 4.2 will this work? Been trying to look for good ones. Thanks mate!
Best Answer06-09-2019 09:05
06-09-2019 09:05
Yeah, 4.2 should work no problem.
