01-20-2020
06:26
04:22
DavideFitbit
01-20-2020
06:26
04:22
DavideFitbit
So I'm not having much luck connect in my watch to Bluetooth to play my music
I have three Alexa's an echo show 2 Google home and a Bluetooth speaker. of all those devices I have only been able to get it to connect to 1 Alexa and both Google homes.
So clearly it is able to connect the Bluetooth unfortunately those are not the devices I will head to connect to I really would like to connect to my Bluetooth speaker is there any ideas on how I can troubleshooting why it is not connecting to these other devices
01-20-2020 08:05
01-20-2020 08:05
I'm not following you @Cherylbaker
Your trying to connect what speaker to your Versa.
You mention connecting something to Alex's and Google home, neither of which are hardware.
Best Answer01-20-2020 08:20
01-20-2020 08:20
Hi yes Google home and Alexa are both Hardware and are both able to be used as Bluetooth speakers I don't know what you're talkin about
But I'm trying to connect my Versa to to a Bluetooth speaker and I am not having much luck as I said in my message
Best Answer01-20-2020 08:21
01-20-2020 08:21
I am trying to connect my Versa to any Bluetooth speaker so far of the five I have tried only one works not the one I want I need some help and troubleshooting
Best Answer01-20-2020 09:15
01-20-2020 09:15
Alexa and Google home are services. It is their hardware that connects. For Alexa it may be an Echo device.
To connect the Versa to a standard speaker, you will need to put the speaker into its pair mode. Then have the Versa search for the speaker.
To connect an echo device, you will need to put your Versa into pair mode then ask Alexa to pair the Echo.
As for Google home, I'll let you do your own search.
09:25
04:23
DavideFitbit
01-20-2020
09:25
04:23
DavideFitbit
I'm not asking how to do it I know how to do it I did it it does not work
Best Answer01-20-2020 09:35
01-20-2020 09:35
Are earphones a better Bluetooth option. ???
