02-02-2019 01:07
02-02-2019 01:07
Hi,
I have gotten a brand new Fitbit versa, this is the third one I have gotten (as the previous two stopped working, although i used all the troubleshooting) my Apple IOS 12.1.3 will not sync via bluetooth connection to set up my device. I am wondering if it's the IOS update or my phone or the Fitbit itself.
I have done all the troubleshooting steps on both the Fitbit Versa and on the iPhone, and nothing is working but when used an iPhone 6S with IOS 12.1.2 it connects.
I am starting to become extremely frustrated with Fitbit's (which i think is acceptable), can someone clarify if its due to the update not working with the Versa, or should i just give up on Fitbit's in general.
Thank you
Best Answer02-02-2019 12:18
02-02-2019 12:18
@B_Hardy it's an issue after iOS update. Unfortunately. Fitbit is working on it, I'm sure. For now try this:
If you have Wifi set up, go to Fitbit mobile app and remove it, then sync your Versa. I noticed that it causes issues for me. If you have other Bluetooth devices paired with your phone, forget them. One of them might be causing issues. Also, make sure All day sync is enabled.
02-02-2019 12:18
Best Answer02-02-2019 12:28
02-02-2019 12:28
Best Answer02-02-2019 12:32
02-02-2019 12:32
@B_Hardy is your Versa linked to your account? You mentioned setting up... What can you see on Versas screen after it boots?
Best Answer02-02-2019 12:34
02-02-2019 12:34
Best Answer02-02-2019 12:39
02-02-2019 12:39
@B_Hardy I see. Between step 5 and 6 you will have to set up your tracker. Basically plug it to charger near your router as you will be using wifi to download the firmware. Open Fitbit app, tap on the account icon (looks like a business card) and go to Set up a Device. Choose Versa. You will be asked to replace the current one. Confirm and follow the instructions on the screen. Good luck.
