03-14-2024 06:29
03-14-2024 06:29
I had body temp until yesterday which showed high.i went to doctors and turns out ive got start of puemonia. Id like to getvit back on
Best Answer03-14-2024 08:59
03-14-2024 08:59
Hi, @Van1lla1, welcome to the community, non of the Fitbit devices measure your body temperature, you can see skin temperature variation in the "Health Metrics" tile on the Fitbit app you have installed on your phone. How can Fitbit help me track my temperature? - Fitbit Help Center provides guidance & advice.
I hope this helps.
Cheers
Gr4ndp4 | UK
03-14-2024 10:30
03-14-2024 10:30
Hello @Van1lla1
Which Fitbit device do you have?
From other posts I've read, the Body Temperature tile in the Fitbit app was available during the Covid pandemic. Apparently, it was removed when it seemed that Covid was no longer declared a pandemic. A recent Fitbit app update restored this tile, likely due to the release of the Pixel 8 Pro which has a temperature sensor.
You can restore the Body Temperature tile by using the pencil icon on the Today page:
You should now see a separate Body Temperature tile on the Today page. When you tap on the tile, you can manually enter your body temperature and track it throughout the day, as needed.
03-14-2024 10:40
03-14-2024 10:40
Best Answer03-14-2024 10:50 - edited 03-14-2024 11:00
Hi @Van1lla1
Thanks for letting me know that you have a Versa 3.
I moved your post from the Android platform forum to the Versa product help forum since it seems the issue is with your device and not the Android app. Hopefully, someone who has experience with the Versa 3 can help you.
Best Answer03-14-2024 11:11
03-14-2024 11:11
