Hi, there are some Clock Faces that gives you the opportunity to let your displyay of your Versa alsmost all of the day on. Your should, however, realize that this will minimize the duration of your battery, which is normally 4+ days, and you will need to charge it more often. Nevertheless, if that's what you want: Go to clock faces - press all clocks - type in the search bar: Classic and it will show up on top of the list on the left side and choose install it . This clock has the option of always on display between 6:00 AM and 09:00 PM, after which its's automatically turns od this option to save your battery. Furthermore, this Clock Face is not only highly customazably but also very battery friendly by it's small size. Try it out for a few days and hope you will like it and fits your needs.
