02-17-2019 05:11
02-17-2019 05:11
I'm on my second Fitbit versa and my call notifications aren't coming through. I've checked the Bluetooth setting, Fitbit access , and that my incoming calls are set to urgent. I get all other notifications but call butbit would tell me when I miss a call. Please help !
02-17-2019 20:42
02-17-2019 20:42
@VIgirl Phone model and OS?
02-21-2019 04:08
02-21-2019 04:08
03-17-2019 10:42
03-17-2019 10:42
I have a Samsung galaxy s9 & have this issue too. When I first brought the watch it worked fine but suddenly stopped working & tried everything to get it going again but nothing works. I get the missed call notification but that's useless when the main reason I brought the watch was for call notifications.
Seems to be a common issue but any way of fixing it???? Every other notification works fine & all settings in place to allow calls?!?
03-19-2019
12:51
10:17
03-19-2019
12:51
10:17
@Twig1974 It's great to see that you've visited the Fitbit Community! Sorry to hear about your issues getting call notifications on your phone and thank you for troubleshooting this issue. You can try going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try syncing them. Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on. You can find additional suggestions here.
Let me know how it goes.
03-19-2019 15:42
03-19-2019 15:42
Thankyou for your response....I've tried everything listed numerous times but still no calls coming through. Everything else works just call notifications.
03-20-2019
07:52
10:17
03-20-2019
07:52
10:17
@Twig1974 thank you for your update. Could you share a screenshot of the call notifications page (this setting in particular).
I look forward to your reply.
03-20-2019 13:41
03-20-2019 13:43
03-20-2019 13:43
Have I attached what u require?
03-21-2019 04:33
03-21-2019 04:33
03-21-2019 13:21
03-21-2019 13:21
TRY THIS>>>
Not sure if it will help but I have an android (Samsung Galaxy S5) device and have had multiple issues with receiving text notifications on my Versa. I have read forum after forum to find answers and finally I figured out it was an issue within my phone. I went to settings, SOUND AND NOTIFICATION>>scroll all the way to the bottom and you will see NOTIFICATION ACCESS>> open this and you should see the Fitbit Notification Service and you will need to slide the button to ON. This may not help you with your specific device but that is what I found to be the culprit! Hope this helps.
03-21-2019 15:23
03-21-2019 15:23
Thankyou for taking time to reply. Just checked this out on my phone but sadly that isn't the cause.... mine was switched on 😞
03-21-2019 15:26
03-21-2019 15:26
It's a joke..... I really haven't got time to ring Fitbit! You buy an expensive smart watch for things such as call notifications & turns out to be a waste of money. Hope u get it sorted....keep us posted!
