01-25-2019 05:04
01-25-2019 05:04
Hi all
can anyone help?
my versa got locked and the app refuses to unlock with new pin. Doesn’t work. Also tried factory restart.. doesn’t work.
so I have since found out that it’s some bug with the Fitbit pay thing which I believe is easy to solve.... but ....I removed the watch from my account as I thought this might help unlock it... but it is still locked, and now I can’t add this device because when locked it doesn’t get the numbers sent to pair it!
so can anyone help my to unlock a watch which is no longer connected to an account?!
Best Answer01-25-2019 05:44
01-25-2019 05:44
Try another factory reset using the buttons, but if that doesnt do it you will have to contact Suppprt (link in my signature )
FACTORY RESET USING BUTTONS
On the watch, hold all three buttons for about twelve seconds. This triggers the 2-button hardware reboot after about eight seconds.
- When the Fitbit logo appears, then disappears, release the bottom right button, then continue holding the left and top right buttons until you feel a strong vibration. This indicates the factory reset was initiated.
- This process may take several seconds, and eventually, the Fitbit logo appears and the device boots and displays go to Fitbit.com/setup.
- If you fail to release the bottom right button in time, or otherwise don't follow the procedure precisely, the Fitbit logo reappears quickly and boots without factory reset.
If the device turns on, please go back to the Fitbit app and setup your device back to your account with these steps. Make sure your watch is plugged into a wall plug or a computer, next to the router and that there are no other trackers or devices with Bluetooth on nearby when setting up. Please log into your account, go to account on the upper right corner, there look for "setup a device" and tap on it. Follow the instructions on the screen and let the watch charge for 2 hours.
Helen | Western Australia
02-07-2019 04:12
02-07-2019 04:12
Any other option I’ve followed and it keeps going back to screen and device lock :locked_with_key:
