01-25-2019 22:35
01-25-2019 22:35
I had to do a reset on my versa and now I can’t connect it. I follow all the steps and put in the 4 digit code the versa gives but all my phone does shows is “pairing your device” but it just sits there. How can I can fix this? This has been my worst experience with Fitbit since I bought the versa
Best Answer01-26-2019 00:58
01-26-2019 00:58
What phone are you using? Is it on the Supported Devices List?
Helen | Western Australia
01-26-2019 08:11
01-26-2019 08:11
@NellyG wrote:What phone are you using? Is it on the Supported Devices List?
iPhone 8plus. It has always connected as I’ve had my Fitbit since February. I had to reset it due to problems I’ve had with it giving incorrect readings
