When I go on a bike ride for exercise, I always take the same route. It's great having the exercise info on my phone and laptop, but I'd like to be able to add checkpoints, or markers, on my route. For example, I'd like to compare my speed/time/etc for section A>B form week to week, and same for B>C, C>D, etc.
Is this possible on a Versa? I was hoping it could be as simple as tapping one of the side buttons...
Thank you all for your help 🙂
Best Answer@KiwiTerm Yes, you are able in a limited way. For example, I set up my hiking workout with cues each 1 km. After completing each km my versa will buzz and give me the stats for that cue. Unfortunately, one cannot set cues reflecting different distances between points of interest. But, it's an awesome idea that should definitely be added to Feature Suggestions Forum! I encourage you to post it there so we can vote for it.
@Exerciseski I start workout exercise on my Versa and after I'm done I rename (edit) it in Fitbit mobile app. you can create your custom exercises there as well. Of course it would be brilliant if I could just start my custom exercise on versa itself. I believe this feature has been already requested on the Feature Suggestions Forum.
Best Answer@KiwiTerm Not for user-defined sections. You can track cues (milestones) though. They can be measured by calories, distance or time.
Thanks for that. I was hoping that I'd be able to track my speeds/times etc over sections of my regular ride. Thanks for the reply 🙂
Best AnswerI would like that to. At the same time I Wonder why it is only a handful og exercise. I would realy like to have skiing and walking with a stroller as well...
