12-20-2018 03:55
12-20-2018 03:55
Fitbit app was updates recently and now the Analog stat and Analog date clock face display the date are the top. Prior to the update analog stat showed step count at the top but now it is showing the date instead. I changed the clock face multiple times to confirm. Why is the analog stat and analog date now showing the same?
12-20-2018 15:29
12-20-2018 17:20
12-20-2018 17:20
The name of the clock face is Analog stat. Original it showed steps at the top instead of the date.
12-20-2018 18:18
12-20-2018 18:18
@KeishaM You probably need to set it in the clockface settings. Open your Fitbit mobile app, tap on Versa icon, tap on Clocks and near the name of the clockface that you're using there should be a gear cog icon. Tap it. I am assuming this clockface allows for some configuration.
