04-20-2018 14:11
04-20-2018 14:11
Just got a Versa and can't figure out how to change the clock face. I'm sure it's easy but can't figure it out.
Thanx
John
Best Answer04-20-2018 15:30
04-20-2018 15:30
You have to do it through the mobile app. Tap on the icon (upper left) for your device and then on Clock Faces.
04-20-2018 15:30
04-20-2018 15:30
04-20-2018 16:54
04-20-2018 16:54
@jheydt wrote:Just got a Versa and can't figure out how to change the clock face. I'm sure it's easy but can't figure it out.
Thanx
John
In the Fitbit App click on the Account Icon at the upper right (looks like a page) and then on Versa at the left and then Clocks.
Best Answer04-20-2018 19:05
04-20-2018 19:05
For the record, you can get to clock faces in the app by clicking on either the device, as I suggested, or by following @SunsetRunner‘s recommendation.
Best Answer04-21-2018 03:29
04-21-2018 03:29
04-21-2018 07:14 - edited 04-21-2018 07:16
@dianewordsmith wrote:For the record, you can get to clock faces in the app by clicking on either the device, as I suggested, or by following @SunsetRunner‘s recommendation.
You are correct, Diane. I use a computer for syncing and tend to forget that the phone app is sometimes different. I have marked your post as the solution for John.
We appreciate the help you have been giving here and hope you are enjoying your new Versa.
Best Answer05-04-2018 20:14
05-04-2018 20:14
Never mind found it. Thanks
Best Answer09-28-2018 12:48
09-28-2018 12:48
You can get some good clockfaces at https://mayer-studios.com/fitbitclocks.html
