12-28-2018
12:29
06:06
GraceGFitbit
12-28-2018
12:29
06:06
GraceGFitbit
Is the Samsung Galaxy S6 Edge Plus compatible with the Versa?
12-28-2018 12:38 - edited 12-28-2018 12:44
Hi, according to this list, the Galaxy S6 Edge is supported but not the S6 Edge plus. But since the Galaxy S7 Edge Plus is supported by Fitbit, you might expect that the S6 Edge plus is also supported. Only cannot guarantee that. Whenever it's not supported, it should not take long before it will be. Good luck.
12-28-2018 12:40
12-28-2018 12:40
Thank you so much! I appreciate your response!
12-28-2018 12:43 - edited 12-28-2018 12:46
You're very welcome, that's why we are around!! Just saw that the link to the list did not work, repaired it so you can see it for yourself. Click the link, scroll down to Android device and to Samsung.
