I have an i phone and answer all my calls via my hearing aides they are super modern only a bit over a year old
They are resound 3D hearing aides
Thanks for response
Best AnswerI have an i phone and answer all my calls via my hearing aides they are super modern only a bit over a year old
Thanks for your response
Best AnswerResound 3D is compatible with Apple Watch (it says in on-line doc) so I bet it is also with the Versa 🙂
>> I’m looking for help to connect my hearing aides to my versa as headphones
Not sure what your problem is? Pairing process is the same as for your mobile. On your Versa, go to settings > bluetooth > add device and put your Resound in pairing mode. Then the Resound name will appear on the Versa and you select it to confirm (if all works to plan). From the manual it doesn't suggest you need to enter a PIN and that's good as that's not possible on the Versa.
