01-05-2019 17:12 - edited 01-05-2019 22:39
I’ve been using my Chase card with Fitbit Pay with no problems on my Versa for 8 months. Last week I changed my phone number and now my CC won’t work.
I was able to add another card and it works fine. But when I tried again today to use my original card, it says “Card failed”. I’ve uninstalled/reinstalled the Fitbit app. I’ve erased and reinstalled the card. Still won’t work. CC is fine, not expired.
Help?
01-05-2019 17:48
01-05-2019 17:48
So what happens when you try to add the card, do you get any errors, when you contacted your bank, did they have any record of this?
01-05-2019 22:39
01-05-2019 22:39
01-29-2019 21:25
01-29-2019 21:25
Ok I’ve contacted the bank and they say “It’s on Fitbits side.” I contact Fitbit and they suggested factory reset. They said if I sub my Versa I won’t lose any information.
Gas anyone one lost their data after doing a factory reset?
01-29-2019 21:26
01-29-2019 21:26
Ok I’ve contacted the bank and they say “It’s on Fitbits side.” I contact Fitbit and they suggested factory reset. They said if I sync my Versa I won’t lose any information.
01-30-2019 01:10
01-30-2019 01:10
As long as you have synced before the factory reset you will be fine.
However I would first on Fitbit revoke the credit card, then add it again.
