07-31-2018 18:58
07-31-2018 18:58
How do I change colors or customize clock faces on my Versa?
Best Answer07-31-2018 19:32
07-31-2018 19:32
Not all clockfaces are customizable.
Some clockfaces can change color (or display different information) touching the screen while, more commonly, some others require you go to to the clock faces settings that can be reached via your smartphone Fitbit app, pressing the Versa icon on top right, then clockface and finally on my Clock tab is the clock face is customizable you will see a gear icon settings symbol to be pressed.
