06-10-2018 10:36
06-10-2018 10:36
I woke up this morning to a completely unresponsive Versa. No light flashing on the back, no sign of life, no charging potential. Has anyone else had this happen? I got it at the beginning of May through Amazon and have had absolutely no problems with it. About to contact customer service.
06-10-2018 10:55 - edited 06-10-2018 10:57
06-10-2018 15:47
06-10-2018 15:47
I just had this happen to me today and resetting it worked. Press and hold the back (or left) button and bottom button at the same time for about 10 seconds. The Fitbit logo should come up on the screen.
06-10-2018 15:52
06-10-2018 15:52
06-10-2018 16:14
06-10-2018 16:14
The same thing happened to me today. I know my Fitbit battery died the night before so I set it on the charger thinking it would charge overnight at least. Woke up to find that I can't 'power on' my Fitbit using the back (left button). I found this forum and using the reset technique (left button and bottom right button) my Fitbit did turn on. Thank you for your suggestions!
PS My only question now is: Will this happen every time I let the battery die??
Best Answer06-10-2018 19:01
06-10-2018 19:01
@amychasenh wrote:I just had this happen to me today and resetting it worked. Press and hold the back (or left) button and bottom button at the same time for about 10 seconds. The Fitbit logo should come up on the screen.
Yes, Amy, it's called a Restart as I recommended in the post above yours.
06-11-2018 04:21
06-11-2018 04:21
We're all just trying to be helpful! Please try to stay kind.
06-11-2018 04:28
06-11-2018 04:28
You are absolutely correct, Amy, and I apologize for my unwarranted abruptness.
06-11-2018 04:48
06-11-2018 04:48
My battery level was still in the green when I went to bed. There was absolutely no response in any way. Very strange. I love it so much, love the Fitbit app too. Customer Service were very helpful.
07-07-2018 11:25
07-07-2018 11:25
I bought a Fitbit Versa that died after only 44 days of use. I tried returning it to Target but since it was past the 30 day window, I was not able to. Anyway, contacted Fitbit customer support and after doing all troubleshooting, they ended up sending me a return label to send it back to them. It was completely dead. Anyway, it has been 3 weeks since I sent the Versa back and I haven’t got the replacement. At this point I wish I could get my money back (over $200) but they don’t do refunds.
The quality of Fitbit and its customer service is TERRIBLE!
07-07-2018 11:54
07-07-2018 11:54
08-06-2018 11:11
08-06-2018 11:11
Unfortunately, same thing happened to me!
It was just on 60% and then it all went black. I tried re-charging. The interface goes back up but won't get past to 1%. Once you take it off the charger, it's just dead! I tried to troubleshoot + factory reset but nothing works.
I contacted customer service. The chat agent was great. I am now doing an e-mail exchange. They decided that it might just be the charger. They'll be sending a charger replacement instead. I'm from the Philippines so imagine how long will that take. Imagine also the frustration when I try the new charger and it still doesn't work and it ends up being the hardware fault at all.
Oh! Quite frustrating!
Best Answer08-06-2018 11:35
08-06-2018 11:35
Did you by any chance swim with your versa?
08-06-2018 11:43
08-06-2018 11:43
Yes, I swam with it on pool water last July 4, definitely less than 50 meters deeps. I'd say I was swimming in it a 12 ft deep pool.
My versa broke down only after a month, dead on August 4.
Best Answer08-11-2018 03:13 - edited 08-11-2018 03:14
@vintagechutzpah wrote:Unfortunately, same thing happened to me!
Just an update. The charger arrived within one week. They shipped it from China so it was fast to get here in the Philippines. Unfortunately, it ain't a charger problem. I plugged it in the new charger they gave me but it reacts the same way. I've just e-mailed them now asking what to do next.
I called in the retailer wherein I purchased the Fitbit from. It's still under warranty. So, that's an option to just give it back there. The process time though would take 2-3 weeks as it has to go to their HQ and personally inspect it before any decision of giving a new replacement or what have you.
WHAT A HASSLE. Anyway, I'll wait for the Fitbit team to reply first.
Best Answer08-11-2018 04:57
08-11-2018 04:57
ok, they're replacing it, finally. and they're quick about it. looking back, i'm quite impressed on the customer service.
yes, there's still worry that in another 3 months, this might happen again. yes, it makes you think on why I didn't get the apple watch instead. but yep, looks like I'm still going to enjoy my Fitbit Versa until it lasts.
Best Answer05-27-2019 08:35
05-27-2019 08:35
mine just died too....wasn't holding a charge and just died..only 3 months old
Best Answer05-27-2019 08:36
05-27-2019 08:36
didn't work for mine it's dead
Best Answer05-27-2019 10:41
05-27-2019 10:41
I had a similar issue with my Versa. Battery was malfunctioning. I contacted Fitbit support and they promptly sent me a replacement Versa as my warranty was still valid. I suggest you to contact Fitbit support team. They have a very reliable team. Would definitely help you.
Best Answer08-14-2019 07:15
08-14-2019 07:15
The exact same thing happened to me yesterday. I can’t get it to charge or turn on. Just got this watch 2 months ago.
