I can't pin down a time frame when this started, but my Versa does not show email or text notifications (are setup in the Fitbit app) for hours after they appear on my phone. Samsung 9+. I've done a factory reset of the Versa and started over. No change...still get notifications much later that they appear on the phone. Usually between 30 minutes to an entire day...~24 hours.
Best AnswerRestart of the Versa first. That didn't make any difference. I then removed software and BT connection from my phone and started over; Fitbit app and BT connectivity.
Best AnswerIf you did a factory reset, you will need to setup the Versa all over again to the Fitbit app, cause a FR does what it says, bring the Versa back as if it still was in the factory and never been sold, let alone been setup. Hope this helps.
