Deleting exercises from versa
How do I delete an exercise from the versa watch? I  hit the treadmill exercise while playing around with the watch and now I can't figure out how to get it off the watch.
 I deleted it from my log on the fitbit website
4 REPLIES 4
I'm not 100% sure what the question is, but here we go:
To delete the Treadmill , you need to go to the app. Go into the settings for the tracker, and find the section called Exercise Shortcuts. There you'll find a list of the exercises installed on the watch. Just delete any of the ones you don't use. You can add others there also.
If you're wanting to delete the log of exercise altogether from the watch, know the watch displays the last 3 exercises performed. So when there are new ones, that one will fall off the list as it is replaced. But it can't be deleted from the watch.
Hope one of the answers addresses your question.
Work out...eat... sleep...repeat!
Dave | California
@Sigma723 I deleted a few exercises too. I opened the app, clicked on the Versa icon top right corner. Scroll down to Exercise Shortcuts and click on it. Press and hold your finger on Treadmill and swipe left. Sync your Versa and treadmill will be deleted.
Hope this helps.
Thank you. That helps
Thank you. I meant that I wanted to delete the logged exercise on the watch. If it holds the last 3, that's fine. I'll just wait for it to get replaced
