I've had my Versa (G1) not for a while, and by & large it's pretty OK.
Running v.72.1.9
After my initial purchase & setup, I've really not had much cause/time to mess with it much, but there's some basic functionality that I need to alter/upgrade, particularly the apps I use.
I've tried resolving this issue before though preferred channels, but the p!$$-poor support I've received & the tools at my disposal to enable me to dig into the problem has put this in the "too hard" basket at the time.
Most of the "support" consists of - what I can only guess is - a pre-set auto-bot script of "reset the device, reinstall the app(s)" or "contact helpdesk so I can get upsold into buying the new model", aka. the "have you tried turning it off & on" IDGAF support-model.
Yes, I have... several times, across several host devices.
Basic gist & what I've tred incudes - after device factory reset & apps uninstall-flush-reinstall:
But regardless what I do, I simply cannot get past the "Oops, looks like there's no Internet connection", which is complete b/s!
Having the simple ability to connect - via USB cable - from my desktop app to the watch so that I can do some BASIC maintenance, i.e. remove what's unneeded and/or side-load & config apps because the mobile app and/or watch seems incapable of doing so itself, does not seem a tall ask.
No - I will NOT contact tech support again. They're not been helpful in the least in the past!
No - I will NOT buy a new model, as I've taken careful care of this multi-hundred dollar piece of kit that still functions just fine as a watch, despite the apparently horrendous code-quality & non-support. There's no guarantee a replacement model won't suffer the same "support" issues, so the smarter move would be to go with another vendor capable of providing support!
Device build-quality has been OK, but everything else around this experience has been abysmal.
Hi @kieppie can you describe the issue that you are having?
Does your tracker sync it's data to the cloud?
Your tracker does not communicate through USB.
The fitbit app handles the BTLE connection, their is nothing the user can do here except to approve the apps request to pair the tracker.
Hi @Rich_Laue,
What exactly do you mean here?
If there were more useful error codes or debugging resources available, there would be far less grappling in the dark.
Well, no, actually it does, but the manufacturer chose not make that basic function accessible.
When plugging it into a PC, it registers as a pretty standard COM device:
[ 4871.824363] usbcore: registered new interface driver cdc_acm
[ 4871.824365] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 4897.577909] usb 3-2: USB disconnect, device number 10
[ 4899.878003] usb 3-2: new full-speed USB device number 11 using xhci_hcd
[ 4900.032590] usb 3-2: New USB device found, idVendor=2687, idProduct=fd10, bcdDevice= 1.00
[ 4900.032595] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4900.032598] usb 3-2: Product: Versa
[ 4900.032600] usb 3-2: Manufacturer: Fitbit
[ 4900.032602] usb 3-2: SerialNumber: REDACTED
[ 4900.036686] cdc_acm 3-2:1.0: ttyACM0: USB ACM device
So no, the tracker IS capable of communicating through standard serial - even if some sort of "secret handshake" or key exchange is required to facilitate debugging/service between the desktop app & tracker - but this has been purposely disabled.
Again, the problem or agency is not with the customer/owner, but with the vendor that has chosen to lock owners out of their device, and therefore the only resolution need to be forthcoming from the party that has these keys and control - the vendor.
Sure, whatever.
I've tried numerous times to unpair, reset, reload the tracker from the devices & have apps handle the re-pairing of the tracker - both BT & BLE - with the same results.
No matter which way I dice this, I'm still unable to do some of the most basic functions with this stack, and considering the utter lack of control over my own piece of hardware I paid for and own, the responsibility to resolve this is not with me, but on the remote end.
Either resolve this issue, or provide us the means to do so ourselves!
I don't care about the warranty being voided - effectively a contract that implies "you will fix it if I don't break it" - since clearly is doesn't mean squat!
Best AnswerAre you trying to write a program to access your tracker directly, or asking for help with your tracker and the fitbit app?
Best AnswerThe long response in the prior post is to provide sufficient information to any interested users that encounter this (common) issue on how to debug, given the limited access available.
Not trying to write an app - given this experience that's very much in the "too hard, life's too short"-basket - but simply trying to access the device from my mobile/desktop app(s) in order to add/update/config/remove apps & settings, i.e. the most basic of reasonably expected functionality.
I would like to install additional apps to make this device more useful, such as basic web-hooks/triggers, but that's simply not on the cards because of this issue.
I've also looked into other causes, and the one that's probably most applicable to me is DNS-blacklisting, ala Pi-Hole & Ad-blocking.
I've whitelisted as much as I could see on my gateway & tried various WAN connections (process-of-elimination variables including my own WAN & mobile connections), and alternative DNS servers, such as 1.1.1.1, 9.9.9.9, 8.8.8.8, 8.8.4.4, etc
There is very little in the way of authoritative information on which IP's or DNS's to whitelist, so again this is grappling in the dark & hoping for the best, with absolutely no information - local or remote - I can use to debug this issue.
Maybe this can be a good starting-point:
