01-23-2020
12:28
20:07
RicardoFitbit
01-23-2020
12:28
20:07
RicardoFitbit
Hi,
My Fitbit versa device has gone off abruptly. It is not restarting even after charging it for around an hour. . I have tried all the methods shared in the forum and even tried out factory reset but nothing worked. Even tried a different charger but still it is not coming up
Could anyone please help me with this issue?
01-23-2020 12:44
01-23-2020 12:44
Contact Customer Support.
Best Answer01-24-2020 20:06
01-24-2020 20:06
Hi @goyala, welcome to the Community Forums!
Thanks for your post and troubleshooting this situation prior to posting. To better assist you with this, can you please let me know if the heart rate sensors of your Versa are still flashing? Do you feel any vibration on your device so we can determine that this is a display issue? If you haven't already done so I recommend you to check our help article: Why isn't my battery charging on my Fitbit device?
@SunsetRunner Thanks for your support and suggestion!
I'll be around.
Best Answer01-26-2020 23:09
01-26-2020 23:09
Hi,
Thanks for your reply. Heart rate sensors of my versa are not flashing. Also there is no vibration on the device.
19:22
06:35
01-29-2020
19:22
06:35
Your update is appreciated @goyala, sorry for the delayed reply.
Thanks for troubleshooting your device. I'd like to share with you that our Support team informed me that they already provided you assistance to resolve this situation. That said, I recommend you to contact them back if you require further assistance or if you have any additional questions about the information that they provided to you.
I'll be here if you need anything else.
Best Answer01-29-2020 19:57
01-29-2020 19:57
Mine did the same thing and I just took it off the charger.
What things did you try?
Best Answer02-04-2020 12:36
02-04-2020 12:36
Hi @RicardoFitbit ,
Thanks for the response. I have actually tried out all the steps that support team asked me to do but nothing worked unfortunately. Could you please help me out on what else can I try to make my device work?
