Thanks. Do you know if its in the work to disable automatically?
I mainly want this so that it doesnt vibrate while its in the charging mount and rub against the mount.
Also since its not on my wrist while mounted for charging I don't need it to vibrate to notify me.
Best AnswerThe reason to automatically shut off vibration while charging is that steps are counted due to vibration. This morning I woke up to 40k steps logged from being on the charger.
Mine keeps vibrating when charged. I tried shutting it down to charge and it's STILL doing this. The random vibration on this watch is driving me *nuts( - I have turned off ALL the things and it still will randomly start to vibrate for no reason. H E L P.
Best AnswerMine just started doing this and my last resort was to do a Factory Restart. Which is the setup is not working because the Versa keeps vibrating in the charger and the app won’t recognize it. Is it fried?
