04-18-2018
15:25
04:36
AlejandraFitbit
04-18-2018
15:25
04:36
AlejandraFitbit
Hi, I would like to buy the Fitbit Versa but I want to know first if it does work and synchronize on my Huawei Mate 8 phone via the Fitbit app?
04:38
09:56
04-19-2018
04:38
09:56
Hey @Ale22, a warm welcome to the Community.
Regarding your inquiry, Huawei Mate 8 isn't a compatible phone, which means you might experience some issues at the moment of connecting it with your Versa. To see which phones you can use, you can take a look at our list of compatible mobile devices.
Keep in mind that you can always sync your Fitbit with a computer or another compatible device.
I hope this helps, let me know if you need anything else. ![]()
04-19-2018
04:38
09:56
04-19-2018
04:38
09:56
I'm sorry Fitbit, but this is an absolutely horrible response. It has been over a year and a half that Fitbit has known that they were having syncing issues with Huawei phones. They sync fine with apples and they sync fine with Samsung but for some reason Fitbit doesn't like Hawaii phones. They already huge phone manufacturer, why do you just ignore them.
Best AnswerThat's what turns out you can look in the Google Play Store and there is an app that will help your phone syncs to the Fitbit. I installed it and it is working perfectly. It's a darn shame that Fitbit programmers can't get off their own butts to do something like this.
Best AnswerI wana buy fitbit versa for my brother and he uses hawaii Mate 8? Is there any solution that i can be compatible with that.
Thanks
