04-26-2018 09:32
04-26-2018 09:32
I can not figure out how to get my new Versa to track the miles when I am on the elliptical? Anyone know how to do that. I tried putting it in Work Out mode.... but I do not think it is right. I love the watch but I love the eliptical... I loose all those miles I do on that.
04-26-2018 09:40
04-26-2018 09:40
I enter the machine distance manually after working out. With varying stride length, it is impossible for a fitbit to track accurately.
Best Answer04-26-2018 09:41
04-26-2018 09:41
I am learning that but on Ios App I do not see how to log activity
Best Answer04-26-2018 09:58
04-26-2018 09:58
It is logged on the fitbit app. If you go to exercise, button top right.
Best Answer04-26-2018 10:00
04-26-2018 10:00
oh i see you go into the exercise map and hit log. I didnt see that. SO If I put I calories in there it will add the miles or do I created a new on for elliptical?
Best Answer04-26-2018 10:01
04-26-2018 10:01
I will have to try I do not see how to add the miles though.
Best Answer04-26-2018 16:22
04-26-2018 16:22
On the first page of the phone app you should see a pentagon showing --of-- days exercise. Hit that and it brings you to a screen with a stopwatch in upper right corner. hit that and a screen opens allowing you to track previous exercise. add the miles travelled and it should configure everything else including calories.
Best Answer05-30-2018 06:45
05-30-2018 06:45
how does one enter it manually x
Best Answer05-30-2018 06:46
05-30-2018 06:46
what button what top right ?
05-30-2018 06:46
what ex map X
Best Answer06-05-2018 14:09
06-05-2018 14:09
I have tried many times to add miles. It will not. Unless it had recorded it with the mileage. I actually just put the watch in Workout Mode now. Because that will give me Caloires and Mileage. And Afterwords I edit it to describe Elliptical.
Best Answer07-26-2018 18:52
07-26-2018 18:52
I have found what works for me is to take the watch off and place it near my hip in at top of gym shorts (which have a tight elastic band). I put on Workout and it measures my heart rate, steps, miles, etc. accurately and then if I want I can go in afterward and edit the Workout to call it Ellipitical but to be honest all my workouts tend to include an use of an ellipitical machine so I often just leave it as Workout. When I went in and just added it manually, it would only allow me to enter calories burned so I never got credit for the steps, which is frustrating. (Now if I could get the Versa to track my sleep correctly - I think that is a lost cause until Fitbit addresses that issue with the watch - a friend of mine has the Icon and that does have this problem.)
