12-17-2019 10:27
12-17-2019 10:27
Why is this now available on only some Charge 3 and Versas?
04-07-2020 17:39
04-07-2020 17:39
Thanks for answering.
I had it for a few days, and it suddenly disappeared. Now the frame is blank. I tried to reinstall the App twice, with total data clearing, but with no positive effect. The graph still doesn't show any data lines 😔.
I'm a Charge 3 user, on Galaxy S10, as my wife. And everything works well with her devices...
04-07-2020 17:50
04-07-2020 17:50
04-07-2020 18:12
04-07-2020 18:12
04-07-2020 19:37
04-07-2020 19:37
04-08-2020 12:13
04-08-2020 12:13
Just an update once I uninstalled the Fitbit app on my iphone one of the only was to clear the catch 😞 and repositioned the versa on my wrist according to the 3 finger rule just above the wrist bone I got a sleep score and and oxygen score hope this helps others.
04-08-2020 13:37
04-08-2020 13:37
04-08-2020 13:38
04-08-2020 13:38
04-08-2020 15:36
04-08-2020 15:36
04-08-2020 15:37
04-08-2020 15:37
04-10-2020 02:30
04-10-2020 02:30
04-10-2020 04:27
04-10-2020 04:27
04-12-2020 09:02
04-12-2020 09:02
Hello @CVSRI85 have you looked at the Fitbit Help Docs?
04-13-2020 14:58
04-13-2020 14:58
I had to reset my device for it to work.
Go to settings on your device, uncheck the heartrate on to heart rate off. Sync device. Go back to settings, turn on heartrate again. Put device into charger. Press and hold for about 8 seconds while it is in the charger, it'll reboot, and when it's done, a 🙂 should show up for a moment.
Take it out of charger (cradle, whatever you want to call it)
Sync again with app. It showed up the next day when I synced my device again after sleeping.
This worked for my charge 3.
(I hope this made sense)
It was mildly annoying, but hey, i have lots of time right now.
04-13-2020 18:10
04-17-2020 06:12
04-17-2020 06:12
So ... this graph is no longer available with the Charge 4, then?
I had data on this graph with my Charge 3 until I swapped to the new Charge 4 - now it's blank.
04-17-2020 09:11
04-17-2020 09:11
04-17-2020 09:43
04-17-2020 09:43
04-17-2020 12:02
04-17-2020 12:02
It's supposed to. According to the release announcements and all articles, it's supposed to be exactly the same as the Charge 3, just with on-board GPS, FitBit Pay, and a few other internal features. Externally, it's supposed to be the same.
04-17-2020 14:34
04-17-2020 14:34
04-17-2020 15:07
04-17-2020 15:07
