09-17-2020
09:06
11:28
DavideFitbit
09-17-2020
09:06
11:28
DavideFitbit
I have a Versa 2. The last Firmware update loaded the "find phone" feature on my Versa2. But everytime I click it on my smart watch it finds my tablet instead of my Android phone. How do I set it to find my phone instead of my tablet?
09-17-2020
14:13
11:29
DavideFitbit
09-17-2020
14:13
11:29
DavideFitbit
I do use the tablet for syncing more than the phone because I find my Versa 2, nor any previous fitbit devices I have had, sync very well with the phone. It constantly says can't find device no matter what I do. My charge HR that I had previously I constantly had to do a hard reset to sync. But the Versa2 seems to discourage hard resets so don't know how to get it to sync. It has been one of my main complaints with Fitbit devices. Will consider other devices next time around that maybe are more phone friendly.Sent from my Verizon, Samsung Galaxy smartphone
Moderator edit: format
Best AnswerYou should try turning Bluetooth off on your tablet. I had a similar problem with my VL before it stopped working, it would always sync to my tab instead of phone, because I set it up on my tab and the Bluetooth on that was always on. OR if you need Bluetooth ON for your tablet turn off locations.
