01-03-2019 08:43
01-03-2019 08:43
My previous Fitbit was a charge 2 and the battery would last almost a week. I’ve had a versa for Christmas and the battery seems to last 48 hours not reaching anywhere near 3 days...is this normal?..I’ve turned off all notifications on it to try and save battery power?
Best Answer01-03-2019 09:16
01-03-2019 09:16
Do you have Bluetooth on? That will drain the battery.
Also, check your Display Awake timing (10 seconds is best) and set your Brightness level to Auto.
Best Answer01-03-2019 09:37
01-03-2019 09:37
Hi Susan, yes I have blue tooth on but i have turned display off unless I press the button, very disappointed in the Versa battery life as I had everything switched on my Fitbit charge 2 and it lasted ages.
