06-27-2018 14:11
06-27-2018 14:11
Hi, the FitBit Versa is a great FitBit, but it won't sync. I usually have to make it sync 10 times and it still won't sync. I try restarting my bluetooth but that doesn't work either. Normally the Versa will only sync when the app restarts my bluetooth, but when I restart my bluetooth it will not work. Does anyone know the solution? Thanks!
Best Answer06-27-2018 23:29
06-27-2018 23:29
The most likely way of getting syncing to work is to restart your phone and then restart your fitbit. For the Versa you do this by:
07-01-2018 17:58
07-01-2018 17:58
Ok, thank you for the help, I will try that.
