04-23-2018 08:15
04-23-2018 08:15
I am trying to setup my new Versa and it is telling me "Fitbit Bluetooth Services are full" Because of that it can't seem to find my Versa, yet it shows up in available devices.
04-23-2018 11:15
04-23-2018 11:15
Good luck! A lot of people are having syncing problem which is probably why you can't get bluetooth connection. My connection has not been more than a few hours at anyone time over the past 4 days, and no one can explain why its happening
04-23-2018 08:25
04-23-2018 08:25
Have you tried restarting the watch by holding the left button and bottom right button in till the fitbit logo comes up (About 10 seconds)?
Then you could try restarting your phone.
How many paired devices do you have on your phone?
04-23-2018 08:33
04-23-2018 08:33
04-23-2018 08:36
04-23-2018 08:36
I had trouble keeping it paired to my Bluetooth when I first got it too.
but after I did the factory reset on the watch I haven’t had any trouble with it.
04-23-2018 08:36
04-23-2018 08:36
In your phone settings open the Bluetooth settings, see if there are Fitbit devices there - if there are, select them (On mine it's the normal settings cog thing) and Forget them
See if that helps
04-23-2018 08:41
04-23-2018 08:41
04-23-2018 09:22
04-23-2018 09:22
04-23-2018 10:51
04-23-2018 10:51
04-23-2018 11:01
04-23-2018 11:01
04-23-2018 11:11
04-23-2018 11:11
04-23-2018 11:15
04-23-2018 11:15
04-23-2018 11:15
04-23-2018 11:15
04-23-2018 11:17
04-23-2018 11:17
04-23-2018 11:54
04-23-2018 11:54
Would you suggest I go into Settings on my phone and try setting up the device again? It will ask me if I'm replacing my Versa even though I didn't get thru the setup the first time.
03-24-2019 19:01
03-24-2019 19:01
I'm having the same exact issue. A fee days ago, my watch stopped syncing. I forgot the device on my phone but now can't get it to reconnect. When I click on versa in my Bluetooth, it either tells me incorrect pin or it tells me the Fitbit Bluetooth services are busy.
I've restarted the watch, the app, my phone and nothing can get this watch connected .
