Fitbit Today Delay (Versa)
ANSWERED
Hi,
I like to check my floor count quite frequently and when I swipe up to see the floor count, the Fitbit Today splash screen shows for about 1.5 seconds prior to displaying steps- at which point I can swipe left to get to floor count.
First, is there any way to remove this splash screen and/or delay?
Second,  can I get floor count to display with the default clockface as it does for heart rate, steps, and calories?
Thanks,
Matt B.
1 BEST ANSWER
Accepted Solutions
Hi, I assume your on the latest Firmware version with the updated Today app. Swiping up usually was directly present in the former version, but, in my case, it takes about half a second before it displays stats. the reason for that is that it has to collect more information than earlier and the more activities you activated, the longer it takes. So, AFAIK , you cannot do anything about it. But all in all, what's 1,5 secs?
Regarding stairs in your default clock face, this is not possible. in order to get stairs, you will need to install another third party clock face which has this possibility. I know a clock face that has this possibility and it's size is soo small that it's even battery friendly. It's just a very simple and basic clock face but highly customazible and only 35 kB. It's called "Classic" and you can find it by going to Clock Faces - All Clocks - press that and type in the search bar "Classic" abd you will find it on top of the list on the left side. It's not so colourfull as your default one, but just give it a try. You can walk through your stats by pressing in the middle of the clock. It begins with steps and, as I already mentioned, also floors/stairs. It's even faster than the Today screen. Used it myself for quite a while but changed it to another one because I do not need stairs. Again, give it a good try and you're gonna love it. Battery will last at least for 4,5 days on one charge. good luck.
2 REPLIES 2
exactly what @SunsetRunner said 🙂
Elena | Pennsylvania
